1996 Seville Trunk release issues
Old May 20, 2009 | 09:59 PM
justtalkin's Avatar
Default 1996 Seville Trunk release issues
My trunk is unaccessible due to not being able to release the latch either my switch, remote fob, or key. It appears the lock mechanism is jammed, or stripped out. Initially the problem surfaced with the glove box and fob release. The latch would not release electronically. So, we used only the key in the lock. Finally, the key will not work either. The key turns within the lock cylinder, but nothing releases. The glove box electrical release actuates the solenoid, but the latch will not release. You can hear the solenoid clicking, but not releasing. I am mechanically able to replace the latch, but can not find a way into the truck. I have tried prying up on the trunk lid while using the key, or key fob. No success. Does anyone have a similiar experience? Is there a better way to release the latch, rather than drilling out the lock cylinder and manually destroying the latch?
Old May 21, 2009 | 04:17 PM
at first, im thinking the key is sooo worn, but thats not it...... do you have a valet switch on the car that is turned off........ ???? or on? valet is, if you dont know, a way to secure valuables in the trunk, or glove box and those two things be disarmed, or armed..... hope it helps
Old May 21, 2009 | 06:07 PM
justtalkin's Avatar
Thanks, kindly for your response. I am familiar with the valet switch...turned it off and on and that does not make a difference. Although with it on, nothing happens....with it off, the solenoid does click, but not release. The primary key is worn, and I tried several replacement keys. Each key turns, but does not release the latch. The key fob makes the latch click, but the latch will not release. It seems that something in the latch is stripped. Or not fully engaging. Any other ideas are greatly appreciated.
Old Dec 17, 2017 | 03:10 PM
CaddyClownin88's Avatar
Did you ever find the fix for this issue?
Old Dec 17, 2017 | 03:17 PM
justtalkin's Avatar
Never found the solution. Very unhappy with the gas guzzler. Junked the car out of frustration.
Old Dec 17, 2017 | 03:19 PM
justtalkin's Avatar
Bought a Toyota. Very happy with reliable, fuel efficient, trouble-free car.
cman187
Feb 23, 2021 06:28 PM
nalv420
Jun 3, 2020 11:01 AM
mikelpayne
Aug 24, 2009 06:22 PM
jheald
Jul 29, 2008 06:43 AM
bshanor
Aug 19, 2007 11:01 PM
