1996 Seville Fuel injection hose leak under plenum
Old Jan 31, 2009 | 04:54 PM
justtalkin's Avatar
Default 1996 Seville Fuel injection hose leak under plenum
My 1996 Seville recently developed a pin hole leak on the fuel injection hose that runs under the manifold plenum. I temporarily sealed it off with a piece of rubber and a small hose clamp. But, obviously the entire hose needs to be replaced. The hose appears to be plastic that was factory installed. Does anyone have any experience replacing this hose? Thanks for any advice.
Old Jan 31, 2009 | 08:04 PM
There is no fuel hose under plenum. Does car have black plastic or silver metal fuel rail going to injectors?
Old Feb 19, 2009 | 02:46 PM
dalamak's Avatar
Black plastic fuel rails were recalled due to leaking problems, also might want to just get an Fuel injection O-ring kit and replace them, its cheap and easy.
Old Mar 18, 2009 | 12:28 AM
justtalkin's Avatar
Thanks for your earlier reply. My car still has the black plastic going to the injectors? Is the recall still in effect? If not, how do I replace the black plastic? It appears to be molded on the injectors somehow. Thanks for additional input.
Old Aug 10, 2009 | 09:29 PM
justtalkin's Avatar
Thanks for your earlier reply. My repair job has lasted several months, now. My 96 Seville has the black plastic fuel hose running between the injectors. How big of a job is it to replace these hoses? Does anyone make an after market kit?
Old Aug 10, 2009 | 09:33 PM
justtalkin's Avatar
Old Aug 11, 2009 | 01:40 AM
regardless of the difficulty get it done .. an explosion there, should it happen, will likely star a fire in the engine compartment.
predictions of when such events can happen are not predicable.
Old Aug 11, 2009 | 07:16 PM
To find out if recalls applies to your car contact local dealer with VIN and they will be able to tell you if they need to be done. Recalls are free provided it applies to your car.
Old Aug 13, 2009 | 08:44 PM
justtalkin's Avatar
Dealership handled the recall replacement fast and efficiently.
Old Jun 4, 2010 | 06:41 PM
justtalkin's Avatar
Default Another fuel leak on the plastic line
My 1996 STS has suffered another fuel line leak...plastic fuel line coming up from the subframe to the fuel rail bolted to the engine. This time the leak is right where the transmission cable rubs up against the plastic fuel line. What are the replacement options? A repair kit? Or a complete replacement fuel line?
CTSWorkinProgress
Jan 6, 2008 10:32 AM
nauc
Sep 11, 2006 07:04 PM
Bernard
Aug 16, 2006 12:46 AM
nobse
Apr 25, 2006 12:22 AM
crotonoil
Sep 12, 2004 01:45 PM
