Manual knobs for soft top latching
Old Apr 19, 2009 | 01:00 PM
theatreman's Avatar
Default Manual ***** for soft top latching
Is there a trick to getting the ***** to lock down the soft top? One of the power motors works (passenger), but the other side (driver) will not lock down with power motor. I tried to lock this side down with the manual ****, but no luck. Am I overlooking something? Thanks!
Old Apr 19, 2009 | 02:54 PM
very common issue. you dont need the power motors to lock it in place.
you will find a spline shaft coming out on the side of each pull down.
you can turn it fairly easy by hand with a hand towel - gently pulling down on the top as you turn the spline makes it go faster.
or get a socket to fit it .. if you do that, make sure it is the exact fit or you will damage the splines. cant remember the size that fits.
Cadillac Allante FAQ
Sep 16, 2019 03:35 PM
theatreman
Apr 17, 2009 09:05 AM
Yogi
Mar 17, 2009 07:56 AM
91CBODY
Oct 28, 2008 06:14 PM
Sep 9, 2007 06:12 PM
