Instrument cluster quastion.
Old Jun 12, 2008 | 09:21 PM
BlackSTS's Avatar
Default Instrument cluster quastion.
Sorry, but this was probably asked more then ones. I’m new here and after searching only found that if there is a problem with a cluster that you have to remove it and send it out. I have a problem with a RPM and Shifter positioning left side is DIM, works but no backlight. Right side is perfectly lid. Is that something I can fix my self ore do I have to send this out? Thanks.
Old Jun 13, 2008 | 12:36 AM
brougham1's Avatar
Default RE: Instrument cluster quastion.
Good question, any takers?????
Old Jun 13, 2008 | 08:20 AM
ORIGINAL: BlackSTS
ability to post here is unpredictable but lets try.
check the harness connection and if that is not the problem, contact
Dick at www.allantesoure.com .. fixing it depends on many things ..
also, you didnt specify either year model or digital vs analog.
its important
Old Jun 13, 2008 | 04:00 PM
BlackSTS's Avatar
1990 Model, Digital.
I know that on my Merc I had a light bubl burned out and that was esay fix. I wonder if on a digital cluster it is same light bulb set up ore somthing intergrated on a board. Any one?
Thanks.
Old Jun 29, 2008 | 03:40 PM
ORIGINAL: BlackSTS
Thanks.
i would pull the connector, clean contacts and try again ..
if that fails .. you may be facing the purchase of a replacement unit.
between $100 and $300 in the used parts markets ...
you can also opt for an analog but make sure you also get the bezels and the mileage on the analog cluster will not show your car's mileage (its mechanical) like a digital that reads the ECM.
montemann
Jan 13, 2007 10:23 PM
madmatt2024
Jan 1, 2007 01:28 AM
prairecwby
Nov 29, 2006 05:20 PM
dubz01
Oct 26, 2005 06:42 PM
toms46
Nov 21, 2004 05:10 PM
