Instrument cluster quastion.
Sorry, but this was probably asked more then ones. I’m new here and after searching only found that if there is a problem with a cluster that you have to remove it and send it out. I have a problem with a RPM and Shifter positioning left side is DIM, works but no backlight. Right side is perfectly lid. Is that something I can fix my self ore do I have to send this out? Thanks.
RE: Instrument cluster quastion.
Good question, any takers?????
ORIGINAL: BlackSTS Sorry, but this was probably asked more then ones. I’m new here and after searching only found that if there is a problem with a cluster that you have to remove it and send it out. I have a problem with a RPM and Shifter positioning left side is DIM, works but no backlight. Right side is perfectly lid. Is that something I can fix my self ore do I have to send this out? Thanks. check the harness connection and if that is not the problem, contact Dick at www.allantesoure.com .. fixing it depends on many things .. also, you didnt specify either year model or digital vs analog. its important . |
1990 Model, Digital.
I know that on my Merc I had a light bubl burned out and that was esay fix. I wonder if on a digital cluster it is same light bulb set up ore somthing intergrated on a board. Any one? Thanks. |
ORIGINAL: BlackSTS 1990 Model, Digital. I know that on my Merc I had a light bubl burned out and that was esay fix. I wonder if on a digital cluster it is same light bulb set up ore somthing intergrated on a board. Any one? Thanks. if that fails .. you may be facing the purchase of a replacement unit. between $100 and $300 in the used parts markets ... you can also opt for an analog but make sure you also get the bezels and the mileage on the analog cluster will not show your car's mileage (its mechanical) like a digital that reads the ECM. |
