bose front speaker amp
Old Nov 3, 2007 | 12:09 PM
jono6406's Avatar
Default bose front speaker amp
as mentioned in a previous thread that i picked up last saturday from the local u pull-it yardan infinety q45 front door bose speaker enclousure.this morning i took my door panel off and the speaker enclosure too. the 4" speaker was the same right down to the same part number.(now i have a spare speaker).the amp waspractically identical but had the same connector plug.i saw that the amp i took out of my allante had a small black burn spot on the board.anyway let me tell everyone that it was plug and play.the speaker parts were interchangeable.everything including the connecters werethe same.it cost me $11 for the speaker enclosure. now i have to get the door panel back on.i hope this info is helpful to other allante owner looking for replacement parts.i have managed tobuy 2 more working front door bose amps and have tested them in my system while the enclosure was still open(plug and play)and the ampssound terrific .if anyone needs them i will sell them fora steal.hit me at jno2968326@aol.com.
Old Nov 3, 2007 | 03:53 PM
Default RE: bose front speaker amp
That is good information, I had man with an Allante wait 5 months to get speakers back from rebuilder because amps failed. (not uncommon) New replacement amps were on back order. I think it bothered him a little I had the car from early April til mid October. He got to back so he could garage it a month later.
Old Nov 5, 2007 | 11:23 PM
jono6406's Avatar
sorry the amps were sold today.i will post when more arrive next month.(hopefully)
Old Nov 10, 2007 | 08:42 PM
i just saw the assy / dis-assy in this thread
https://www.cadillacforum.com/m_14902/tm.htm
Old Nov 11, 2007 | 07:07 AM
jono6406's Avatar
hi stomper,thanks for thelink but i had saw that one and it doesn't provide nowhere near enough info.it really tells nothing about aligning the floating plate with the door handle holes which is the key to getting the job done.
Old Nov 12, 2007 | 07:17 PM
jim's Avatar
jim
ORIGINAL: jono6406
As I recall when I put mine together(# years ago),I remember that floating plate, and I placed some modeling clay around the plate to align it to stay in place then reassembled. It saved a lot of aggrivation.
Old Nov 12, 2007 | 08:05 PM
I wish I knew, but I been lucky and had not had to deal with that.
However, if it is a matter of hodling TWO parts aligned, may i recommend a bit of BEE's WAX?
For several decades, bee's was has been part of my tool bags. IT holds just about anything together so that
one can perform assy. Readily used by the USAF in assy of jet aircraft and engines.
IF you dont have a hobby shop near by, go to the supermarket and buy a jar of honey with the honecomb
in the jar. There is your bee's wax, the honeycomb.
lol
Old Nov 12, 2007 | 08:06 PM
lol
Old Nov 12, 2007 | 09:48 PM
jono6406's Avatar
too late.i had the door panel put back on byan allante specialist in the tampbay area but i must bring it back because i noticed that my drivers door won't lock and when i do lock it and someone opens it up the factory alarm goes off and i have to put my key in the lock and turn it.
Old Nov 13, 2007 | 01:18 AM
steveoa1
Jan 9, 2010 05:45 PM
katta lac kate
Aug 11, 2009 11:33 AM
jono6406
Jul 30, 2008 08:38 PM
Jul 30, 2008 11:21 AM
G.A.R.Y.
Mar 12, 2008 12:55 PM
