Digital Dash Lights and Starter Replacement
Old Jul 15, 2019 | 01:46 PM
ironmule's Avatar
Default Digital Dash Lights and Starter Replacement
Hello to all,
I have a 1996 Fleetwood Brougham.
The nose of the starter snapped. Looks like it was not shimmed properly.
Went to NAPA and purchased a new starter. While reconnecting the battery, the starter very briefly engaged.
No key on. Went to try starting and the digital display goes blank and starter does not crank. When I release the switch from the start position dash returns to normal readout. Battery voltage was 12.4V. All connections are clean and tight. I have bench tested the starter twice and it works fine, just not when it's installed on the car.
Also I have checked the fuses in the I/P and under the hood. All good. I checked for codes and none are displayed.
My questions are the following:
Could the temporary bump of the starter cause the control module(s) to fail?
Could this be an anti-theft system problem? (The anti-theft light on the dash lights for 3 seconds and goes out when the key is turned to the on position.) The GM manual states that as normal. What else can I look for?
oldmanrooster
Sep 13, 2018 02:53 PM
trentlane
May 12, 2018 07:34 AM
Rhw
Nov 7, 2015 11:03 PM
fizzy55
Oct 12, 2008 02:48 PM
bih5
Feb 5, 2008 07:22 PM
