1988 devill starter?
Old May 26, 2009 | 12:26 PM
trentlane's Avatar
Question 1988 devill starter?
I just got a 1988 devill sedan(4.5 enjected) and when we hooked up a new battery the horns (all 4) went off. We unhooked them for now but my main problem is that the starter only clicks like its engaging but not turning. My dad thinks that we need to replace the starter OR its something in the stearing column. The engene turns over so we kjnow its not sceased. What do you all think? Plus if anyone can advise me as to how to get the starter out that whuld be great aswell.
p.s. if any of you know where i can get a key for the hubcaps that whuld be handy aswell.
Old May 26, 2009 | 12:46 PM
sounds like a security system is running, with your horns goin, and wont let the car start........
now you say the starter just clicks but not turning, then you say the engine turns over..........?????????????? whats up with that?
check your spare tire wheel well for the key for the wheels....
Old May 27, 2009 | 05:15 AM
trentlane's Avatar
we got the car started yesterday, we ended up taking the starter out and cleaning it up. started first try! i found the key it was in the jack box so thanks for the help didint think to look in the wheel well. still got the problem with the horns tho we are thinking its a relay. if you all have any suggestons it whuld be helpfull.
Old May 7, 2018 | 09:30 AM
Vinn's Avatar
Default 1988 350 cu in eng. starter.
it looks like the starter is right behind the front bumper. as to the "fixer upper" rigs I buy, I like to take the starter out after most of the other problems are solved.. totally disassemble the starter for inspection and re build (if nessary), AND make sure its not "rebuilt in china". vin
Old May 12, 2018 | 07:34 AM
Vinn's Avatar
look for corrosion in contacts or grounds. may have to take the steering wheel off. vin
lucke77
Vintage & Classic Cadillacs
May 10, 2011 10:56 AM
redneck11
May 23, 2010 08:15 PM
PooreBoy
Big Block V8s
May 22, 2009 10:18 PM
theatreman
Nov 10, 2006 01:15 AM
motor44
Aug 29, 2006 07:27 AM
