2005 Escalade Rear Pasenger Side Window Does Not W
Old Nov 3, 2007 | 06:59 PM
umoms's Avatar
Default 2005 Escalade Rear Pasenger Side Window Does Not W
[hr] I tried the main controls and the controls by the window. I dont hear any sound at all. All 3 other windows work fine and sunroof. I checked the fuses and they look good.
Any ideas?
Old Nov 3, 2007 | 07:25 PM
Default RE: 2005 Escalade Rear Pasenger Side Window Does Not W
You may have bad motor or either window switch. I suggest to find out if you are getting power and ground to connector that plugs into motor.
Old Nov 3, 2007 | 08:47 PM
umoms's Avatar
If the window dont go down from the driver side controls or the rear passenger side control could it still be a bad switch?
Old Nov 3, 2007 | 09:28 PM
Doing a little checking, circuit has module and relays along with switches. Motor is mostly failed part.Your still need to check for power and ground at connector. If power and ground are there, you will problely need a scanner to figue it out. Isn't technology wonderful
Old Nov 3, 2007 | 09:47 PM
umoms's Avatar
a OBD II scanner will tell me which part is bad?
Old Nov 3, 2007 | 10:00 PM
A GM Tech 2 downloaded with dealer software will let you check switches and override relays and module.But you still need do voltage and ground checks to know for sure.
Old Nov 5, 2007 | 08:00 PM
umoms's Avatar
Took 2 bolts off the door trim to take it off. Then 3 bolts fom the power window motor. Got power to the motor. Swapped with another power window motor and it worked fine. Took a total of 30 minutes.
JoerobustoJoesilhavy
Jun 13, 2012 09:24 PM
wrathofdad
Oct 26, 2011 06:47 PM
J Sauce
Jan 1, 2009 11:40 PM
Peter_Reinhard
May 7, 2008 10:01 AM
khanawalt
Dec 8, 2007 09:11 PM
