Simple Fix? Replacing fuses/ add resistor for 1998 ETC "STARTING DISABLED" error?
Old Nov 19, 2019 | 12:34 PM
BigTCaddy93's Avatar
Default Simple Fix? Replacing fuses/ add resistor for 1998 ETC "STARTING DISABLED" error?
Hopped in my 98 the other day and had my heart broken immediately when I turned the key. I've been messing with it since and as far as I can tell based on research and such is that the two wires that connect to the ignition switch have probably broken.
Replacing the ignition switch is a large task involving removing the steering wheel so I'm looking for an alternative way.
Has anyone gotten around this problem using a resistor they wired on themselves? I've read about it but not too sure what I'd need to do. I doubt a fuse would fix it but literally anything short of removing the steering wheel would be massive help.
shartpants
Aug 11, 2010 08:59 PM
DJWerkz
Mar 16, 2009 10:41 AM
davefr
Eldorado Biarritz
Nov 29, 2008 08:01 PM
unkut
Mar 19, 2007 04:06 PM
mikew
Feb 27, 2007 09:37 AM
