Idiot lights
Old Jul 21, 2017 | 02:50 PM
Hi O Silver's Avatar
Default Idiot lights
So I converted my rear shocks/struts from auto leveling system to struts ( to save $), but immediately the traction control and the anti-lock lights appear....& "service stability system " appears on the info bar.
Am I correct to assume these lights will be forever on the cluster? 01 Eldorado esc
thanks anyone😳
Old Jul 21, 2017 | 03:02 PM
traction control and abs lights - be sure wheel speed sensors are plugged in and fluid is not low. Changing shocks shouldn't cause DTC.
Service stability system warning is probably forever. There maybe a way to trick module with resistor but I have no info on how to do it.
Old Jul 21, 2017 | 03:14 PM
don't know about wheel sensors, the mech said not to worry about the lights, but I worry some😕.....plug in??
Old Jul 21, 2017 | 03:17 PM
With new shocks shouldn't fluid to full?
Old Jul 22, 2017 | 06:44 PM
brake fluid - if its low will turn on abs/tcs warming. The shocks should not effect abs or traction control.
fluid is not added to regular shocks
Murdock117
Sep 3, 2012 08:54 PM
TERRYRIC
Apr 6, 2009 10:51 PM
BOBBYRIC1
Jan 13, 2009 07:50 PM
xmguyx22
Nov 6, 2008 08:10 PM
TDL
Oct 24, 2007 05:05 PM
