Idiot lights
So I converted my rear shocks/struts from auto leveling system to struts ( to save $), but immediately the traction control and the anti-lock lights appear....& "service stability system " appears on the info bar.
Am I correct to assume these lights will be forever on the cluster? 01 Eldorado esc thanks anyone😳 |
traction control and abs lights - be sure wheel speed sensors are plugged in and fluid is not low. Changing shocks shouldn't cause DTC.
Service stability system warning is probably forever. There maybe a way to trick module with resistor but I have no info on how to do it. |
Originally Posted by slowroll
(Post 53892)
(Post 53892)
Originally Posted by Hi O Silver
(Post 53893)
don't know about wheel sensors, the mech said not to worry about the lights, but I worry some😕.....plug in??
brake fluid - if its low will turn on abs/tcs warming. The shocks should not effect abs or traction control.
fluid is not added to regular shocks |
