Brake Fluid Switch Problem
Old Oct 18, 2007 | 04:18 PM
scott_mckinney's Avatar
Default Brake Fluid Switch Problem
Hey Guys. I am having an issue with my 1995 Cadillac Eldorado...
Recently I have a new display message on the dash. It reads, "BRAKE FLUID SWITCH PROBLEM, TRACTION CONTROL OFF"
What is the problem with this? I have replaced the brake fluid switch in the master cylinder with no fix... Please advise.
Old Oct 20, 2007 | 07:34 PM
Default RE: Brake Fluid Switch Problem
Mostly likely is a code stored in abs.
Old Oct 21, 2007 | 06:26 PM
Hi. So why was the code put in there? Is this car OBD II?
Old Oct 21, 2007 | 07:29 PM
G.A.R.Y.'s Avatar
I believe pre '96 is OBD I
Old Oct 21, 2007 | 07:46 PM
Your car does not have OBDII, that came for the 96 model year.IF you press off and warmer on havc control at the same time - car will display codes.Codes ares stored when module sees sometime it can't deal with.
CadillacAttack.
Eldorado Seville
Dec 30, 2013 09:16 PM
Steve368Deville
Jul 15, 2010 11:28 AM
jim_h_erie
Jun 4, 2008 10:45 PM
caddyman96
Apr 21, 2008 11:08 PM
belagatyo
Aug 20, 2007 01:21 PM
