ABS
Old Sep 11, 2007 | 05:50 PM
gunkscad's Avatar
Default ABS
Does anyone know where I can get a plug (part of wiring harness) to a brake ABS pump? My harness was in involved in an accident andthe plug isNOT useable. I have an '02, but '00 to '02 will work. ANY help would be very appreciated.
Also, I can not screw my A/C line to the condenser. The threads are stripped. Any thoughts or ideas??? Tried to "rig" it up but that did NOT work. I really need to get the thing screwed together.
Old Oct 3, 2007 | 09:22 AM
Virginia John's Avatar
Default RE: ABS
Not sure about your A/C but couldn't you find a connector in a salvage yard?
Old Oct 3, 2007 | 12:02 PM
76eldoragtop's Avatar
Default RE: ABS
Aluminum? pump down the system, cut off the end and solder on a new one, and recharge? Seems that is possible.
Old Oct 3, 2007 | 03:23 PM
Default RE: ABS
ORIGINAL: gunkscad
- stripepd thread, maybe a insert .. maybe. using damaged threads is often futile.
- '00 to '02 ? dont get it .. pictures?
99STSGUY
Aluminum Block V8s
Jul 7, 2010 06:52 PM
ruaskier2
Oct 5, 2006 02:59 AM
gunkscad
Sep 17, 2006 11:00 AM
gunkscad
Aug 22, 2006 11:22 PM
onecool
Jul 10, 2006 03:23 PM
