ABS
:)Does anyone know where I can get a plug (part of wiring harness) to a brake ABS pump? My harness was in involved in an accident andthe plug isNOT useable. I have an '02, but '00 to '02 will work. ANY help would be very appreciated.
Also, I can not screw my A/C line to the condenser. The threads are stripped. Any thoughts or ideas??? Tried to "rig" it up but that did NOT work. I really need to get the thing screwed together.:D |
RE: ABS
Not sure about your A/C but couldn't you find a connector in a salvage yard?
RE: ABS
Aluminum? pump down the system, cut off the end and solder on a new one, and recharge? Seems that is possible.
RE: ABS
ORIGINAL: gunkscad :)Does anyone know where I can get a plug (part of wiring harness) to a brake ABS pump? My harness was in involved in an accident andthe plug isNOT useable. I have an '02, but '00 to '02 will work. ANY help would be very appreciated. Also, I can not screw my A/C line to the condenser. The threads are stripped. Any thoughts or ideas??? Tried to "rig" it up but that did NOT work. I really need to get the thing screwed together.:D - '00 to '02 ? dont get it .. pictures? |
