'69 Eldorado electrical problem
Old Mar 26, 2014 | 04:06 PM
whit's Avatar
Default '69 Eldorado electrical problem
I'm new to the Forum...have a '69 Eldorado...51K actual miles. My problem is that, when the rigtht turnsignal lever is engaged, the engine dies and all electrical shuts down. I think it is a short in the turnsignal/ignition wiring in the steering column.
Before I dive into that, I thought I would ask if others have seen this phenomena and how to fix it?
Thanks Whit
Old Mar 27, 2014 | 11:08 AM
Not sure what you will find for cause, but it sound like top of column needs to come a part. The turn signal switch needs to be taken loose and lifted a little. Check how ignition cylinder mechanical linkage operates ignition switch is actually at bottom of column. Steering columns are particularly difficult to work on at the same time they are easy to mess up. You need manual, although GM columns did not change much from 1969-85. If in doubt take it to a reputable shop.
Old Mar 28, 2014 | 06:30 AM
whit's Avatar
Thank you slowroll...I was fearful that taking apart the upper steering column was the likely outcome her. I will go after it and report back in due time.
Thanks again for the input.
Whit
mdlaughlin
May 6, 2010 12:31 PM
MathD106
Apr 29, 2009 01:28 AM
Vasile2
Sep 22, 2006 10:47 PM
devilleconcours100
Aug 29, 2006 12:50 AM
ghostdeville
Jun 23, 2006 07:06 PM
