2001 Ride Control hissing
My car does this also, which is normal. The suspension is filled with air. For example, if you have a car-load of people the motor will pump more air into the suspension to keep the car level. When everyone exits the vehicle the suspension will release the excess air causing the hissing sound. This is normal when you first start the car, you will hear the motor running then release some extra air. If you hear the motor running excessively for 7 minutes or more at a time, then you may have a leak which is not so serious, but should be taken care of. Hope this helped! =)
cadillacowner
Jun 5, 2014 12:39 PM
01devilledude
Jul 28, 2010 03:46 PM
