1992 Eldorado A/C Compressor Replacment
Old Aug 23, 2017 | 02:36 PM
Carney's Avatar
Default 1992 Eldorado A/C Compressor Replacment
Hello,
I have an eldorado with the 4.9L. The compressor had a catastrophic failure and I purchased a variety of parts to clean and repair the system. However I am having trouble getting the A/C compressor off the car. The front bolts (on the pulley side, by wheel well) are out but I cannot get the rear torx (I assume haven't actually seen them well enough) bolts to come out because of the motor mount down there. The mount is so close to the bolts I cannot get a driver in the space.
Question 1: Is this normal or do I have an extra big motor mount or compressor or something?
Question 2: I see the bolts for the bracket that connects the a/c compressor to the motor mount bracket in the block. I cannot get them loose :-( Any tricks?
Basically how did any of you get the back off the car???
Thanks,
Carl
Old Aug 24, 2017 | 04:08 PM
You got the 3 bolts out of the front. Unbolt the bracket, in back of compressor, from the block. Transfer bracket don't tighten all the way until after attaching it to block.
Old Aug 24, 2017 | 05:41 PM
Carney's Avatar
I am just having a hell of a time getting those bolts off on the bracket. Tried PB fluid, impact gun, etc. I just either can't get the angle on it or don't have enough torque to take them out.
If anyone know anything that would make these bolts easier to get to or take out please let me know. In the mean time I guess I will let them soak in PB.
americanclassicg
Oct 26, 2008 04:19 PM
gedarren_d
Eldorado Biarritz
Oct 6, 2007 10:09 AM
gedarren_d
Jul 15, 2007 10:12 PM
gedarren_d
Jul 14, 2007 04:21 PM
niceguyjps
Aug 16, 2006 01:56 AM
