Rear ride control
Old Sep 1, 2018 | 01:17 PM
DAVECAD2.0's Avatar
Default Rear ride control
Working on a friends 2002 Deville DTS. Pulled DIC codes and am getting a RSS C0662. Level control exhaust valve circuit low. Pulled compressor and bench tested it. Replenished the filter/dryer. Compressor runs and builds pressure. Checked the coil on the compressor head (Two white wires) with a VOM. No continuity. From reading other posts, the exhaust, or air bleed down is controlled by this coil and is normally closed. The coil is rusty, looks bad. So guessing its the coil? Checked the shocks with shop air. They extend and hold air. Checked resistance at both shock coils, 13 ohm's. Body wiring harness feeds 12v to compressor wiring. But compressor does not run on car. If you think it's the coil, is the compressor head available as a separate part?
Also checked all fuses and relays. Sat.
Thanks, Dave.
Old Dec 22, 2018 | 11:54 PM
peter.handscomb's Avatar
i want to replace my speed sensitive suspension with passive struts. however i
want to keep the level ride feature.
Old Dec 23, 2018 | 02:17 PM
DAVECAD2.0's Avatar
Default Ride control
[QUOTE=peter.handscomb;55613]i want to replace my speed sensitive suspension with passive struts. however i
want to keep the level ride feature.[/QUOT
There are specific struts for this replacement. The vendors supply a electrical plug for the circuit so it doesn't keep throwing a code. The brands are on this thread somewhere I remember reading them.
Dave.
lewisdk6
Oct 19, 2015 05:41 AM
johnv6
Jan 9, 2014 07:12 PM
The Rookie
Jul 7, 2010 06:45 PM
strabo40
Mar 12, 2010 11:43 AM
mrdaley
Feb 8, 2009 01:35 PM
