Radiator Help
Old Dec 7, 2007 | 04:05 PM
caddydoug's Avatar
Default Radiator Help
New to the forum, does anyone have experience changing the radiator in a 97 DeVille. Any hints, tricks etc would be greatly appreciated Thanks, Doug
Old Dec 7, 2007 | 08:18 PM
Default RE: Radiator Help
Not hard,but no fun. Keep coolant away from abs unit.
Old Dec 9, 2007 | 04:21 PM
caddydoug's Avatar
Could you elaborate on that? Any hiden , not obvious bolts? Do the fans come out first? etc[8D]
Old Dec 9, 2007 | 07:45 PM
Remove radiator hoses, dog bones, sir sensor, disconnect trans. cooler lines, oil cooler lines if present. removing left cooling fan may help with removing lower trans line, panel that holds radiator at top. A/c condenser may attach to radiator. Take attching screws loose and separate from radiator. reverse to install
fox's girl
Feb 3, 2013 06:34 PM
greg2169
Feb 20, 2011 10:41 PM
cleven
Jun 7, 2007 07:50 PM
Charlie
Feb 22, 2007 10:33 PM
topaz92
Apr 14, 2005 02:36 PM
