need help with radiator leak- i guess
Old Dec 16, 2012 | 09:05 PM
fox's girl's Avatar
Default need help with radiator leak- i guess
Can I get some suggestions? No leak origination is noticeable however keeps running out of antifreeze. What's wrong? Its running hot.
Old Dec 17, 2012 | 01:52 PM
EricD's Avatar
Can't tell you where leak is but it could help if you included model and year of your car - also how much it is leaking. Radiator shop?
Old Dec 22, 2012 | 12:08 PM
OldsD88's Avatar
Check the obvious, the radiator cap. If may be bad, permitting the anti-freeze to evaporate or boil out?
Old Feb 3, 2013 | 06:34 PM
SimpsonTruckDriver's Avatar
Simple test: have someone stand behind the car and turn it on, look for bluish smoke from the tailpipe. Puff of white is normal (water vapor). Then, drive until the engine is warm/hot (15-20 miles) without A/C on. Shut off the engine, and open the hood. Listen for any hissing or bubbling sounds. DO NOT OPEN THE RADIATOR!
A sweet-smelling smoke from the tailpipe usually means a head gasket or cracked head (big $$$). Hissing from the radiator is pretty easy to fix, buy Bars Leak (under $10) - either Copper or Aluminum will seal the leak perfectly.
TS
deadbug
Feb 7, 2014 09:28 AM
thickskins
Jan 21, 2008 02:29 PM
lferrebee
Aug 23, 2007 04:36 PM
wpbrink
May 8, 2007 08:59 PM
Mar 3, 2007 01:23 PM
