fan blower
Old Aug 19, 2007 | 08:00 AM
blondie's Avatar
Default fan blower
I recently had my air conditioner repaired. all it was, was a vaccuum hose repaired. the air worked great. the next week i took it to be inspected. the guy said it wouldnt pass the emissions and would have to fix stuff. he said he had to replace monitors or sensors or something. my check engine light finally went out but now, my fan does not blow (too bad for me haha) at all not hot, or cold. could he have screwed something up under my hood or what?????????/
Old Aug 19, 2007 | 05:57 PM
brougham1's Avatar
Default RE: fan blower
Hey Blondie: Check your fuse first of all. To be sure it is not a bad motor take a hot lead to the fan motor connector and see if your motor runs, if it does you will have to check all your connections up to that point. If it doesn't run off a hot lead then you will need a motor replacement.
lugocnc
Sep 4, 2010 08:58 PM
kleankicks
Jun 26, 2010 06:59 AM
KathyMartin
Nov 9, 2008 01:35 PM
barbaranna
Jun 6, 2007 11:02 PM
barbaranna
May 23, 2007 10:11 PM
