digital dash
Old Aug 2, 2010 | 08:11 AM
juliosjav's Avatar
Default digital dash
having a problem with my digital dash flashing on and off, i was told it could be the bcm, if so where is the bcm located? thanks, john.
Old Aug 2, 2010 | 09:43 AM
Sorry......... Year, Make, Model........ lol, read your post, can you answer that....lol
Give the Forum more information....... Is that all that is acting up? When does it do it? .....As you are driving car, sitting still, when you first start it up. Do you know, or can you pull any codes??
Old Aug 2, 2010 | 10:06 AM
juliosjav's Avatar
sorry new at this, its a 1989 4.5 sedan deville,not driving the car just bought it to sell, as soon as you start it the dash starts flashing on and off, other times the dash lights right up and works fine,then after a few minuets it starters flashing again. not able to get any codes. thanks for the help, john.
Old Aug 2, 2010 | 10:40 AM
okay, so...... it had been sitting 12 years, and the battery HAS NOT been changed??? whoops, mixed up with another post...
I'd for sure replace battery.
dash flashing at times..... ???? have you checked plug-ins etc?? sometimes that could be related to ignitiion switch..... hmmmm
get battery replaced, ......see what happens after that.... let the forum know.
good luck
Sorry, i keep getting your post and another mixed up........ you dont have a battery problem, do you??
Old Aug 2, 2010 | 11:53 AM
juliosjav's Avatar
good luck
yes, the battery wont stay charged,replaced batt. twice, had alt. checked was ok. thanks, john.
Old Aug 2, 2010 | 01:56 PM
ohhhh... you got a draw somewhere...... hopin somone will chime in on this one... something is running/on all the time. that could be a tuff one, or ??? maybe easy. check all electrics, see if something is on/running.
Old Feb 1, 2011 | 10:35 PM
ELLISTX's Avatar
Default battery drain
Check and see if the Clock on the radio stays on with the key off....
Aug 14, 2009 10:23 AM
brendanw
Feb 12, 2009 12:28 PM
parlain44
Nov 10, 2008 12:06 PM
padosd
Sep 21, 2008 08:00 PM
Cadillac Allante FAQ
Feb 28, 2008 11:19 PM
