25979939U Navigation Disc NO LONGER WORKING
Sorry asking for this my first post but the other site I was using doesn't really respond to many posts and most are old post that never actually give a conclusion to the original problem or any answer at all.
Is there anyone out there than can torrent these discs mine no longer works and I have no copies.
assuming they are not bent, broken, or have deep scratches, take them to a music store that sells CD's and ask them to polish them for you .. usually surface scratches keep the laser from focusing and the polishing will make that go away.
lol
2002 Cadillac Deville DTS
I had already cleaned it with a disc doctor and still no dice. What more details do you need?
It is a 2004 Navigation unit re pinned, The previous unit was an 02 Bose AM\FM\CD\WX with an SIR-GM1 Sirius Module Hooked up through the CD changer plug. The last time the disc was working it wouldn't let me put the address in and no POI showed up at all, It was also very sluggish sometimes blanking out the roads.
Here is some random info on the 5th Gen units
By holding the musical note you will get a keypad if you type in 1791 you can play a DVD while driving on change CD's if needed. The 5th Gen NAV you have to put the code in every time the car is shutoff unlike the previous Gen's which retain the code only needing to do this once. There is also another screen with diagnostics 6497.
foxpaws
Oct 10, 2007 10:00 AM
