digital dash
having a problem with my digital dash flashing on and off, i was told it could be the bcm, if so where is the bcm located? thanks, john.
Sorry......... Year, Make, Model........ lol, read your post, can you answer that....lol
Give the Forum more information....... Is that all that is acting up? When does it do it? .....As you are driving car, sitting still, when you first start it up. Do you know, or can you pull any codes?? rickyd |
Originally Posted by rickyd
(Post 38914)
okay, so...... it had been sitting 12 years, and the battery HAS NOT been changed??? whoops, mixed up with another post...
I'd for sure replace battery. dash flashing at times..... ???? have you checked plug-ins etc?? sometimes that could be related to ignitiion switch..... hmmmm get battery replaced, ......see what happens after that.... let the forum know. good luck rickyd Sorry, i keep getting your post and another mixed up........ you dont have a battery problem, do you?? |
(Post 38916)
ohhhh... you got a draw somewhere...... hopin somone will chime in on this one... something is running/on all the time. that could be a tuff one, or ??? maybe easy. check all electrics, see if something is on/running.
battery drain
Check and see if the Clock on the radio stays on with the key off....
