cornering lights
Old Jul 16, 2008 | 12:30 AM
solow's Avatar
Default cornering lights
Thecornering lights on my Cadillac Deville 2002 used to come on when I turned my parking light and/or headlight control switch on, but now they only blink when my turn signal switch is activated. I called the Cadillac dealership and they responded that the cornering lights are only activated when your signal switch is on, although they were on constantly before when I had my headlights/parking light switch on. This makes no sense. My owners manual states that they should be activated when I turn my headlight/parking light switch on, and flash when signal switch is activated also. The bulb is not burned out, no fuses are blown, everything seems to be fine otherwise. The bulb is a 2 element circuit so I don't understand why if its only activated when the turn signal switch is on, why it would have 2 elements. I know they were on before but now they are not.
My questionto anyone that can answer,Is there something I need to turn on in the D.I.C.(Driver Information Center)?????? Any help is apreciated Thanks!!!
Old Jul 16, 2008 | 07:13 AM
Katzmans Caddy's Avatar
Default RE: cornering lights
Cornering lights should not flash at all. The idea is they illuminate the area to the side where you are turning. Proper operation is such that the light will shine steady for as long as you activate your signal. When turn is finished and signal cancels they go off. I think you might have the incorrect bulbs. One circuit only, steady on on turns.
Old Jul 16, 2008 | 09:48 PM
Normally exterior lights have to be on also
Old Jul 17, 2008 | 12:06 AM
solow's Avatar
thanks for the input,but the original bulbs have a two part element and so does the replacement bulb from the dealership.Also in the manual it states in the paragraph describing the cornering lights function and thats what my cornering lights did before was light up when the parking or headlight switch was turned on and flashed brighter when the signal switch was activated and now they dont anymore and bulb is good.Does anybody have any other info on this situation???thanks again
Old Jul 24, 2008 | 07:53 PM
gyalteaser's Avatar
on my deville it works like katzman explained....never like how you explained
Old Jul 24, 2008 | 08:33 PM
ORIGINAL: solow
I think we have some confusion here. Cornering lamps are white. I think you are describing the turn signal indicators which are amber. Please clarify for us.
brickellk
Sep 15, 2012 09:07 AM
Texan4Life
Sep 20, 2010 07:31 AM
theatreman
Sep 20, 2010 07:29 AM
BOBBYRIC1
Jan 13, 2009 07:50 PM
xmguyx22
Nov 6, 2008 08:10 PM
