Check Engine Light
Old Feb 12, 2007 | 06:41 PM
jrm347's Avatar
Default Check Engine Light
I just purchased a 96 Deville, and everything is great on it, except the check engine light stays on. My buddy I bought it off of says that when they put in the new engine, a few years ago, everything wasnt hooked up right, i.e., the sensors and what not, so the light just stays on because it isnt getting an accurate reading. Is this valid, or was he just telling me some story?
Thanks
Old Feb 13, 2007 | 02:56 AM
92_Daddylac's Avatar
Default RE: Check Engine Light
if the guy is telling the truth about replacing the motor he may be right but at the same time that engine may have problems too. try to get the diagnostic codes from the car and look them up in a chilton or haynes book and check the specs. for example if it says thata sensor should be doing some thing at a certain temp ,time or amprage. or whatever check that sensor to see if it is in the right specs. it may be hard be cause if the motor was replaced and the ECU wasnt then the ECU may throw a few codes because of the older engine and the way it ran compared to the new engine.and you may have to see about reseting the ecu memory. this may not be right just check it out and see.
GOOD LUCK
Old Feb 13, 2007 | 03:57 AM
jrm347's Avatar
Thanks man, i appreciate the feedback. I was just wondering if anyone else had heard of the same situation or experienced anything similar.
THANKS
Old Feb 14, 2007 | 01:27 AM
Katzmans Caddy's Avatar
jrm347, in case you are not sure how to get the codes you can read them yourself form the DIC, dash panel in other words. My Deville is newer than yours but in mine with the motor running or accessory keyed you press the off and heat buttons simultaneously until the panel lights up and the codes begin to show. During this process it will pan through all of the various codes and show the history. Have a pen and paper ready to write them down, things like U1255 or P0300, whatever. I'll give you a web site to go and look them up. After all of this the computer will start to go to each code type and ask you if you want to look at them again, press the fan increase speed button, after this it will ask you to Clear Codes?, press the fan increase speed button to clear them. If there are codes in there and this clear codes process does not put the light out your buddy may be telling it like it is. If you clear them all and the light comes on again you are going to have to address the problem, but at least you will know what to look at because the likelihood of numerous codes will be diminished. As it is now you may have a lot of history. One other thing, codes will be marked History or Current (usually stays Current for a few hours when a problem occurs then is religated to History). To reset the DIC turn off the key or as in mine hit the air recirculation button
http://myweb.accessus.net/~090/cadidiag.html
This web has the codes and other information.
Drama
Oct 6, 2020 09:45 PM
99CaddyNH
Jul 17, 2008 06:36 PM
cosmictrucker
Feb 26, 2007 02:35 AM
842heat
Jan 4, 2007 07:14 PM
