Aftermarket Remote start 84' DeVille
Old Dec 25, 2007 | 01:42 PM
tx_boy's Avatar
Default Aftermarket Remote start 84' DeVille
I heard from a couple of people that remote starts are not that good for starters. Do you know if it would mess up the starter on my 1984 DeVille if I put a aftermarket remote start on it. I plan on getting a pager alarm with a mile radius but the only ones are remote starters. What do you guys think about it. Should I get the remote starter hooked up of not? Any opinions would be appreciated.
Thanks!
Old Dec 25, 2007 | 07:48 PM
Default RE: Aftermarket Remote start 84' DeVille
I'm not big on cutting up factory wiring, however if your going to added it, adding the remote start should be ok. You do need to have someone who know what he's doing, and warranties his work. Also shift linkage and nuetral safety switch has to work correctly, or your baby could start and take off without you. If you have any shifter issues even if it's once in awhile DO NOT ADD remote start.
Old Dec 27, 2007 | 12:45 PM
tx_boy's Avatar
Well the shifter safety thing I know about is that you do not have to push on the brake to put it in gear. Not sure if that is normal or what because I have a brake lock for my car and even when it is on and you cant push on the brake as long as the ingnition is turned to A/C, I think it is, you can go through the gears. I dont think I am but just wanted to ask. Thanks for the advice slowroll!!!!!!!!
Old Dec 27, 2007 | 07:13 PM
Your car was built before brake shift interlock. It is more if shift linkage is worn and if you have to search for gears, including park. Setting Parking brake wont help due to auto park brake release.
Old Feb 1, 2011 | 01:33 PM
krk105's Avatar
As long as your car is in park when you turn it off it won't be a problem. i am putting one on my 98 deville right now. They dont hurt your starter if they are hooked up correctly.
mikelpayne
Aug 24, 2009 06:22 PM
theatreman
Nov 10, 2006 01:15 AM
paderolis
Mar 16, 2006 10:54 AM
Imfred
Sep 25, 2004 12:25 PM
