98 deville hvac issues
Old Mar 27, 2010 | 09:09 AM
showtime's Avatar
Default 98 deville hvac issues
98 deville and lately it seems to be blowing hot air out on the passenger side vents regardless of where you set the thermostat????? and i mean hot hot air... i have read elsewhere on this site to look for codes but am unsure as to how to retreive them ????any help is appreciated.
Old Mar 27, 2010 | 07:50 PM
See FAQ section / or search - keyword codes. Passenger side air temp actuator has likely failed.
Old Apr 7, 2010 | 06:24 PM
showtime's Avatar
Default codes
I did find some info with the codes... B 2471 Air mix door two movement fault??? Is this the actuator you are refering to??If so where does this creature live and how hard is it to change??? Any tips would also be appreciated. Thanks to all Eddie
Old Apr 7, 2010 | 07:55 PM
Mounts on hvac case behind glove box.
Randy Mueller
Dec 9, 2014 07:06 PM
Grant A. Van Vranken
Oct 26, 2013 06:21 PM
abaines12345
Jun 8, 2008 11:02 PM
LowBlackLac
Feb 26, 2007 02:06 PM
caddysodry
Jul 7, 2006 06:57 PM
