95 deville complete display out ???
Old Jan 17, 2007 | 10:24 PM
my73deville's Avatar
Default 95 deville complete display out ???
hi everyone,hope we are all enjoying our caddis!!! i just picked up a 95 deville.car runs fine but there is no dash display at all.even the check engine light comes and goes? i cant scan for codes either.it wont give any data? could this be a bcm prob? a bad ground? or bad cluster? ive seen the dash prob before but never all the idiot and check engine lights out too.any help will be appreciated!! thanks, bob.
Old Jan 17, 2007 | 11:15 PM
brougham1's Avatar
Default RE: 95 deville complete display out ???
Hey Bob: Caddy's are fun aren't they!!! You are right when you suggested possible bad ground, as this is behind a good percentage of the issues to do with electronics. Check all the black leads that you can possibly see under the dash and hood. A lot a Caddy's have more than one fuse block as well so maybe see if yours has another . Possiblility of ECC control head as well, so many things and only so much patience to go around. Check Tail-Lic. fuse, check I/P fuse ( of course) all grounds clean and tight. Voltage can be supplied through the tail-lic. fuse tosome of theI/P lights so a good check of the fuse block is in order.Good luck with that....................................
lasmith03
Jun 25, 2014 10:45 AM
Automatic Transmissions
Oct 22, 2007 08:40 PM
lcbmw97
Jan 6, 2007 01:03 PM
rastadr
Aug 10, 2006 11:06 PM
ErikD123
Nov 6, 2004 10:22 PM
