93 Fleetwood Hearse Distributor Removal
Old Sep 8, 2023 | 09:48 AM
Quikjeff's Avatar
Default 93 Fleetwood Hearse Distributor Removal
Working on a 1993 Fleetwood Hearse with a 350 TBI. It is a no start and I am following someone else's work. Fuel pressure is at 10 psi. Found the plug wires in the wrong order, fixed that. Spark was weak. Distributor cap had been installed crooked and there was wear inside from the rotor rubbing. Replaced cap & rotor. Still no start. Spark still seemed weak. Checked resistance on the coil, checked good to spec. Replaced the ignition module because I remember they could be a problem. (Haven't seen a tbi engine in over a decade) Still no start. Took a video of the throttle body while trying to start and saw that the injectors are not firing as they should either. I believe the pickup coil on the distributor gives the signal for Spark and injector so I am trying to remove the distributor BUT there isn't enough room between the motor and the cowl to get it out. Looks like somebody before me tried to get it out because the baseplate that the cap screws to is bent. Is there an easy way to get the distributor out?
badjuijui
Sep 14, 2023 12:44 PM
ploppysator
Apr 27, 2013 05:47 PM
RevHigh06
May 3, 2009 11:38 AM
caddybob
Oct 20, 2007 05:28 PM
Vendor
Mar 15, 2007 11:32 AM
