93 Deville RKE problem.
Old Jan 3, 2008 | 05:27 PM
ron350's Avatar
Default 93 Deville RKE problem.
Hello
Can you tell me where the RKE receiver is located on the 93 Deville?
I have a 93 Deville that the RKE Remote Keyless Entry stopped working. One day both RKE fobs no longer worked.
I can short A to G on the ALDL connector and the door locks work and the trunk unlocks.
Went through both key fobs cleaned contacts and replaced battery’s but did not help.
Old Jan 3, 2008 | 06:02 PM
Default RE: 93 Deville RKE problem.
Reciever I believe in under package tray behind rear seat. Have you tested fobs with fob tester? Availible at dealer and/or some parts stores.
Old Jan 3, 2008 | 06:48 PM
ron350's Avatar
Thanks for the reply Slowroll.
I have not had the bobs tested yet but they are like new and both stopped working at the same time.
I am hoping to find a bad solder joint on the receiver board but they go bad also.
The receivers for the early to mid 90’s W-bodies, Regal, Cutless, etc. are bad about bad solder joints from vibration. Those receivers are mounted under the rear package tray. I was hoping the Deville box would be in a more accessible location. LOL
Old Oct 17, 2009 | 11:29 PM
usvet2's Avatar
Default 93 sixty special
My Rke entry quit. I have changed the batteries attempted to reprogam remote when i use jumper wire the doors will lock and unlock. When i push remote they will unlock once then nothing. Has anyone had this problem. Everything else on car is working. I have read that the trunk should open when the jumper wire is in place mine does not. What can cause this is this part of the problem. Have u found what caused yours to stop working?
Old Oct 18, 2009 | 11:18 AM
Have remote test to be sure it works. Does power trunk work from button in glove box? If not, then it is a separate issue.
Old Oct 11, 2010 | 06:55 PM
rzhj8s's Avatar
Did you ever get this issue resolved? I have the exact same problem on my 92 DeVille. I re-program the remotes including a new one, and the work once then not again. I'm assuming it's a bad receiver which I gather is located under the rear package tray.
Thanks!
JBeam4ME
Jun 17, 2023 04:07 AM
johnjuan43
Aug 20, 2008 09:02 PM
cadillaczak
Jan 31, 2008 11:37 AM
