91 Cadillac Deville E&G designer series # 3108; won't start ...
hi to all I'm new here. I just got this car, 9 21 09 it ran bad but the motor was good with a 134000 on the clock, it is a two door, E&G designer series # 3108. any way I went to start it this morning to work on it, it ran for a moment and that was it, it will not start. at the fuel rail I have 38 psi, I have spark but it will not run. this is my first caddy in 30 years. I will say this, it will be a good car as it got me home, and not standing on the side of the road..
thank you for your help. ________ Vaporizer best value |
you need to pull the codes and post them.
if you dont know how, go to our FAQ and you'll find the pull codes instructions there. |
And now it gets fun, no codes at all from the code reader map is working tps is working no rpm when cranking, test lights on fuel injection not lighting, 37 psi in fuel rail, now what.. I was thinking cam sensor, but when I call a parts store they don't know what I'm talking about
________ Laguna Heights Condo Pattaya |
Originally Posted by kad1012
(Post 34493)
If the CAM SENSOR was inoperative, The CHECK ENGINE LIGHT on the dash would be illuminated. 35 psi for fuel sound low .. could be low fuel pressure and or fuel volume, vacuum leak in one of the engines vacuum lines, contaminated fuel. Some GM engines utilize a CAM SENSOR and a CRANKSHAFT SENSOR and some utilize only the CRANK SENSOR. If the CRANK SENSOR were faulty, In most cases the check engine light would illuminate and or the vehicle would not start. . |
2 Attachment(s)
it will not start, I drove it home, it was running bad and next day it would not start test lights for fuel injectors did not light
________ Medical Marijuana Deispensaries |
(Post 34496)
with this new info, I'm thinking ECM .. let slowroll chime in before you go this way. . |
1 Attachment(s)
I got her to start, here is a pic of her. bad fuse two of them under the glove box, it still run ruff could just be a tune up is all it's needs:D
________ SEX_DEEP |
Tune up is not a bad place to start. Replacing rear plugs ,#6 in particular, is a pain. It's unusual to blow injector fuse(s). Cam sensor/ Hall switch is in distributor which is used to set up fuel injection timing. Distributor orientation is important - if wrong will not set code, engine will run rough. I have heard ethanol in todays gas has cause some fuel system failures. You need a FSM if you don't have one, so you can use the on-board diagnostic functions to help diagnose concerns. Do Not Use Scanners to diagnose DFI Cadillacs(HT4100, 4.5l,& 4.9l) - It can get you off course in diagnosis - Cadillac diagnostic information is designed for on-board, not scanner, to diagnose.
I did a cap & rotor, plugs and air filter. can fuel injectors clog? if so can can I unclog them. As far the fuse go, I had a volvo do that to me, I hate volvo's. This caddy is nice I even have the window sticker from when it was new, $33,933. M.S.R.P it has the digital dash, but the A/C does not work, but one thing at a time.
________ Miramar Dispensary |
(Post 34600)
also, ethanol will GEL as it ages. keeping ethanol fuel in the tank for longer than a month is turning out to be a bad idea. . |
