Issues after double-din kit installation (2008)
I installed a double-din radio kit without issue (with the radio) One of the issues I've had is that the center dash panel became unresponsive, and in order for me to get it to work, I had to take it apart, unplug it, then re-plug it. I later figured out that I can also disconnect a 15A fuse for the radio in the back. I believe that there's an issue with the wires in the harness connecting to the dash panel. Because when I've moved it around a certain way, the controls began to respond to my button presses. The other issue I began to have is, that the temperature display for the driver and passenger lights up, but it doesn't show me anything (mode, or temperature). Some people have said to replace the entire center dash, but, I find that hard to believe. Do those wires come with a part number that I can order ? Or does someone know where I should be looking to fix this ?
sethc1020
Sep 20, 2017 09:00 PM
