flutter noise on deceleration
Old Sep 17, 2017 | 01:07 AM
racerjim's Avatar
Default flutter noise on deceleration
my V6 CTS has a flutter type noise any time I decal. It is not present at idle or at cruise. I have disconnected almost all of the vacuum systems to no avail. Any ideas? I have thought maybe the throttle body blades flutter at the closed position. Any help would be appreciated. racerjim
Old Sep 27, 2017 | 10:54 PM
racerjim's Avatar
I have drilled tiny 1/8 inch holes in both throttle blades. My first road test revealed no more flutter noise. It appears problem solved !!
Old Oct 3, 2017 | 09:36 AM
racerjim's Avatar
Well I am wrong. The flutter is back. Help Please. racerjim
Old Feb 22, 2018 | 10:01 PM
racerjim's Avatar
I have found that the "dirty PCV hose" that I believe has a check valve in it flutters on decel. I removed it and road tested it, NO MORE FLUTTER NOISE I will try to find a replacement hose assy and move on to other things. I hope this may help others that have a similar noise.
04cavillac
Mar 25, 2011 10:03 PM
9treseville
Jun 22, 2008 05:41 PM
gmburd
Oct 5, 2005 04:34 PM
stevel2
May 23, 2005 09:43 PM
DHSDADDY
Dec 15, 2004 12:23 PM
