2011 cts shifter problems
Old 01-20-2018, 04:47 AM
Jonathan Martin's Avatar
Default 2011 cts shifter problems
Hi, I'm having problems with my car. I started the car, put it in reverse, then when I tried to put it in drive (tip-tronic), it seemed to go from neutral straight to tip-tronic. Now it's stuck in the tip-tronic mode but the dash says it's in neutral. It won't go back to the left side, I can't select D, or put it back in Park. I had the car towed to the dealer, they were able to temporarily remove the top shifter assembly, put it in D and drive it in the garage. They told me the shifter linkage assembly needs to be replaced. Total cost in CAD is $570. My question, has anybody encountered this before? I see some shifter linkage assembly repair kits available online, is this what I need instead of replacing the entire unit? Are there instructions on how to do it?
Thank you for any information.
Kik
Automatic Transmissions
11-01-2013 08:33 AM
4dr-ls6
04-27-2011 05:00 PM
mooreman6
Manual Transmissions
11-16-2007 06:07 PM
Dockterj
11-29-2005 11:45 PM
simjack
01-09-2005 10:04 AM
Quick Reply: 2011 cts shifter problems
