'06 CTS ignition fault
Old Sep 27, 2011 | 02:58 AM
W7NNS's Avatar
Angry '06 CTS ignition fault
Hi everyone!
I've got a CTS 3.6 Auto and after parking the car up and coming back to it, the key will not turn in the ignition at all - won't even turn the ignition on, never mind crank the engine. The car is stuck in park.
I've tried some WD40, jiggled the key in every direction whilst moving the steering wheel (which is locked), tried tapping the ignition barrel etc.
I'm over in the UK & there's very limited knowledge of this car here so I'm hoping someone on this forum will have an idea of what may need replacing?
I've read there's a common problem with the ignition barrel on the CTS but usually the key won't turn off - mine won't turn on!
Would welcome any help please.
Old Sep 28, 2011 | 12:26 PM
Cadillac Customer Service's Avatar
W7NNS, sorry to hear about the issues you're having. You should be able to speak with one of the dealers in the area and they should then be able to contact the correct department. You could also contact GM of Europe at 0800 666 222. Hopefully they'll be able to get you all setup. Let me know if you have problems getting into contact with us and I'll do what I can to help out.
Jeff Morris, Cadillac Customer Service
stinger
Oct 16, 2012 05:40 PM
carrdoc57
May 19, 2010 09:21 AM
jsjag
Feb 20, 2007 12:39 AM
dealincain
Nov 11, 2006 09:40 AM
