8-6-4 questions
Old Jul 13, 2007 | 03:41 AM
CoupeDevilln's Avatar
Default 8-6-4 questions
I have a 1981 Coupe DeVille, it has the 368 with V864. I had it disconnected cause it sounds funny in 6 and 4 cylinder mode with my exaust andother reasons.But gas prices are up again and I'm tring to get better gas milage out of it. I want to put it on a switch so I can turn it on when I'm on the highway and off when in town. Will this work okay, has anyone tried it?
Old Jul 13, 2007 | 11:52 AM
brougham1's Avatar
Default RE: 8-6-4 questions
Hey Coupe: I have the 1981 Fleetwood Brougham with this engine configuration and I have the electrical manual for this year. After going over the specs. my recommendation to you is to not tamper with the system. We are talking about buffer amplifiers, computer command control, vehicle speed sensor circuits, unless you are an electronic wizzkid then you will be opening a can of worms trying to put a switch somewhere in the right circuit. You will undoubtedly end up in a world of grief for just trying to save a buck on gas. This is quite a complicated system which also has many subsystems that all work together.The ECM controls the cylinder selection through the MODULATED DISPLACEMENT DRIVER AMPLIFIER . When five conditions are met then the ECM program will select the 6 cyl. mode, when another three conditions are met then the four cyl. mode will take over. All of your circuitry will have to be in near perfect working order for all this to happen flawlessly. Mine does not function at this time and I don't intend to worry about it at all. The problem with this engine too is that there are no mods that I know of to help out in the mpg area. Hope this helps there dude.
Old Jul 13, 2007 | 12:27 PM
Ii totally forgot these things were made.
Does any one know how are the new Dodge Chargers alike these 8-6-4 engines?
This is a write up on the modern Hemi.
Does anyone have a write up on the Cadillac engine?
by Allpar
The 2005 Chrysler 300C and Dodge Magnum RT were the first high-volume, modern production vehicles in North America to feature fully-functioning cylinder deactivation; at Chrysler, they were followed by the 2006 Durango (Honda came out with a cylinder-deactivating V6 later). The MDS (“multiple displacement systemâ€) seamlessly alternates between fuel economy in four-cylinder mode, and power in V-8 mode. Owners receive the powerful benefit of the Hemi engine with the fuel economy that they would expect from a less powerful V6 engine. Most test drivers cannot tell the difference.
"The MDS was part of the engine's original design," said Bob Lee, Vice President Powertrain Product Team, Chrysler Group. "This resulted in a cylinder-deactivation system that is elegantly simple and completely integrated into the engine design. The benefits are fewer parts, maximum reliability and lower cost."
This system should triumph where the Cadillac 4-6-8 failed because of the speed of modern electronic controls, the sophistication of the algorithms controlling the systems, and the use of electronic throttle control. The HEMI will be able to transition from eight cylinders to four in 40 milliseconds (0.04 seconds).
The system deactivates the valve lifters. This keeps the valves in four cylinders closed, and there is no combustion. In addition to stopping combustion, energy is not lost by pumping air through these cylinders.
Fuel economy gains go up to 20 percent under various driving conditions, with a 10 percent (or so) aggregate improvement, without any change in customer experience—drivers will receive the benefit without changing their driving habits or losing power.
Don Sherman's article in Automobile noted described a test of the MDS. They found that only four cylinders were used during 17% of the suburban traffic portion of the test, during a full 48% of the freeway test which included "over 70 mph" speeds.
Overall, they found that the engine powered down to four cylinders about 40% of the time. Non-enthusiast drivers may experience even more savings. As with most testers (including us), Don was generally unable to detect the changes from four to eight cylinders and back again.
Chrysler engineer Cole wrote: "The modern HEMI always shuts off the same four cylinders. In our duarability test cycle (150,000 customer equivelant miles driven at the 95 percentile, meaning that only 5 percent of our owners are more abusive than our testing), we have not found any adverse wear patterns." (Chrysler PR materials boasted of “over 6.5 million customer-equivalent miles through development and durability testing.â€)
for more, look here:
http://www.allpar.com/mopar/new-mopar-hemi.html
Old Jul 14, 2007 | 02:52 PM
You don't think I can run a switch off of the sensor you unplug from the transmisson to dissconnect the 864? I want to switch it cause I don't like the way it acts in town, but need thempg.
Oh and the new Chevy's and Dodges with variable displacement, they only switch from 4 to 8, no 6. There's a odd vibration in 6 mode.
Old Oct 15, 2007 | 08:23 PM
If you keep your foot in it a little , you can keep in 8 cyl mode. In 6 cyl. mode at low engine speeds they all shake, its just physics,and the 368 is a paint shaker. Fortunately they normally don't stay in 6 cyl mode much. The ones I drove a while back weren't too bad in 4cyl. I would leave it alone as long as it working right and learn to drive it so it does what you want it to do.
Old Mar 27, 2011 | 10:58 PM
Wild Bill's Avatar
Default Deactivate 4-6-8
I have an 81 and would like to know how to deactivate to 8 cylinders only. Can any one tell me how?
Old Mar 28, 2011 | 02:42 AM
92_Daddylac's Avatar
you need to look on the side of transmision above the transmission pan for a wire harness with black wire and just cut it. Its the terminal that makes a connection when you hit 3rd gear. it is the one that you want to disconnect to eliminate 8/6/4. It will not set a code when you disconnect the wire. Some people have used a toggle switch for this so on long trips they could get better mpgs. If you search alot of ppl disconected the system and had no issues at all at this time the system was not as complex as it is in todays cars so i dont recomend this on newer cars. this was used back then not only to increase fuel economy but lower emissions aswell but later epa regulations got stricter and these engines had been droped all together.
andyg16
Feb 28, 2007 10:53 PM
89Eldorado
Aug 14, 2006 12:49 AM
andyg16
May 20, 2006 12:36 AM
railven
Mar 24, 2006 03:32 PM
SIK02SS
Mar 15, 2006 01:47 AM
