67 DeVille - Gauges not working
Just bought this 67 coupe. In good shape except the gauges aren't working (I knew when I bought). I was wondering if it's as simple as just putting in a new printed circuit card? Any ideas would be appreciated.
Thank you. Speedo works...bounces a little but works. I need to get behind the dash and check that stuff. Thanks.
Thanks. Makes sense. I went ahead and bought fuses and a new circuit card so I'll have the replacements if I need them while I'm in there and have the dash out.
Finally got to take it for a spin and get some gas. Runs great.
Last night I had tried to start it and it wouldn't. After buying a new battery today and that not working either, I found out one of the many wires running to the battery was loose. Cranked right up after.
Couple of updates. Had the power steering belt tear and car overheated. Did an oil and filter change and added some coolant to the radiator but I don't see a coolant reservoir. I'm not sure how much to add and if this system self bleeds or What?
Secondly, got a new circuit card and gauge overlay to clean that up but I cannot seem to get the instrument panel off. Front is loose and lifts up but I can't see where it's still attached in the rear and the shop manual doesn't seem 100% clear. Any ideas or tips and tricks?? After the overheating incident, I want to get these gauges working so I notice those issues in the future before overheating happens. Thanks
speedo cable still connected? The other would connector in cluster. It's a PITA to climb under dash to see why.
Radiator - no overflow - closed system. There is a line on tank for full cold. About 2 inches below lip of filler should be good.
By tank do you mean radiator? I don't see any fill tank. Any chance You have a pic? I figured I would disconnect Speedo cable once instrument panel was loose. Really feels like bottom rear of assembly is still bolted down somehow.
