1961 Coupe Deville rear window problem
Old Jan 9, 2007 | 03:19 AM
Ermine's Avatar
Default 1961 Coupe Deville rear window problem
Are there any people interested in the "fin era" models? I have a problem with my 19612dht Coupe Deville. I have electrical windows and rear left window is not working. Could anyone give me tips how to remove the window motor? It's in very difficult place and I wouldn't like to cause any more damage by taking it out using too much violence.
Old Apr 11, 2007 | 11:58 AM
belagatyo's Avatar
Default RE: 1961 Coupe Deville rear window problem
Ermine, are you hanging around?
Anyho, a couple of things you should do before tackling the window motor/regulator removal.
[ul] Make sure the problem is not at the switches; If the window won't budge either by the master switch or its own, then proceed to the motor;
Pull the door panel (and the water deflector sheet, if it's still there). Through the big opening try reaching the motor by a piece of 2x4, and just bang on it a few times. Window motors are very durable and the windings seldom burn out; however, the brushes do wear out and it is possible that when it was used the last time, it stopped in a position where it lost contact with the commutators. Often a little nudging gets it going again. Ask me, how I know...
[/ul]
Old Apr 11, 2007 | 03:24 PM
hyperion's Avatar
Unfortunately, even if he is still hanging round he has no rear door panel to pull in his two door hardtop. Secondly I would guess it has been to the local Cad dealer by now for "whatever" they can do. Hopefully finding an old, old mechanic.
Old Apr 11, 2007 | 07:59 PM
belagatyo's Avatar
ORIGINAL: hyperion
... no rear door panel to pull in his two door hardtop.
Oops, [&:] where are my glasses ? The bangin' would still be first on my list, albeit with redesigned tools.
Old Apr 11, 2007 | 09:45 PM
zinzin,
what tonic are you taking for your eyesight?
i need some of that.
belagatyo,
if he was to take out the motor, on that 1961 2dht,
what procedure would you recommned?
Old Apr 12, 2007 | 11:44 AM
belagatyo's Avatar
ORIGINAL: Stealth
[/size]belagatyo,
Step No.1 - Get the Eyesight-Tonic and put it in a cooler;
Step No. 2 - Remove Quarter Window;
[ul]Remove the back seat (cushion and seat back), arm rest and trim assembly. There will be an access hole cover on the inner panel - remove that as well.
Remove the raar guide attaching screws and remove the guide. Unscrew the lower sash channel and remove the cam. Drink a little tonic. Loosen the lower stop and slide it down; Now the window can be removed after some jiggling.[/ul]
Step No. 3 - Remove the Regulator;
[ul] Easy: Unscrew it and pull it out through the access hole;[/ul]
Step No. 4 - Finish the tonic.
vdubluv247
Jul 8, 2014 11:55 AM
RacingJunk
Oct 29, 2013 06:49 PM
Eldo93
Sep 28, 2012 12:24 PM
RagtopBuick66
Jul 25, 2011 04:44 PM
skip
Nov 18, 2007 07:02 PM
