BRAKE FAILURE 83 eldorado
Old Nov 30, 2011 | 11:09 PM
cadillacman4life's Avatar
Default BRAKE FAILURE 83 eldorado
driving on the highway for about 5 miles. got off and stopped at a red light, . i let go of the brake pedal and noticed the dashboard brake light had come on. made a turn and pressed the brakes and got very little response. the pedal felt exactly like a car that has not been started and put in neutral. the brake pedal was hard. i pushed with a lot of force to get the car to stop. i then pushed the gas because i had a feeling that something was just off and it worked. the light went off and the brakes worked. after i tried going slow and the brakes went out again. seemed like when i pushed the gas the brakes worked but when i roll at a slow speed they failed. hope this isnt confusing i tried to explain best as i could. any help is appreciated. thanks.
Old Dec 14, 2011 | 10:43 AM
carnut's Avatar
I know this is late but you might have a failed belt driven vacuum pump. It should put out a steady 19 to 20 in of vacuum.
rufrydermg
Apr 20, 2015 03:04 AM
dror
Oct 15, 2009 09:56 AM
wpbrink
May 8, 2007 08:59 PM
hunter01000
Feb 18, 2007 02:32 PM
LCD
Aug 20, 2006 11:09 PM
