bad brakes
I have an 84 Seville, sometimes the pedal is very hard to push and won't hardly stop the car an other times it goes right to the floor but stops the car better. I have bled the brakes and thats no help. It has a va***m brake booster, could that be the problem?
Bad parking brake actuators will cause very low brake pedal, making car hard to stop. You may need new reman rear calipers and pads to correct parking brake. I suggest to fix parking brake first, then see if your concern corrected.
astrodan13
Aluminum Block V8s
Jun 14, 2011 12:24 AM
Mar 3, 2008 10:14 PM
