ABS & Traction service codes
I have a 2000 Eldo. just put new rotors and pads on it, now the "ABS" & TRACTION" service lights are on, l used my code scanner and it reads "NO CODES SET" so l disconneted the battery for a day and still have the service lights.
You've got a sensor either disconnected or damaged at one of the wheels. The wiring is attached to the strut. Recheck where they plug in behind the caliper. Do a search on this forum for the code meanings.
C1266 LR outlet soleniod malfunction - it is contained within EBTCM. Unfortunately there is no real diag for it. Clear codes if it resets: Replace EBTCM. Replacement EBTCM will need to be programmed by dealer.
jmsnyder
Jun 5, 2021 06:41 AM
jmsnyder
Sep 11, 2012 11:03 PM
simmy
Mar 7, 2011 01:43 PM
andrew61987
Apr 23, 2010 06:41 PM
