97 s10 blazer
Old Oct 19, 2007 | 07:34 AM
FromTheKing's Avatar
Default 97 s10 blazer
i know its not a cady...but guys here were a big help b4
cracking the line right off the master cylinder to the front breaks spits fluid like crazy...but when i crack the other line to the back breaks..it just lightly drips
if i can't a good preasure off the master cylinder(which is brand new)....how can i move on to blead the the whole system and how can 1/2 of the master cylinder have a perfect bleading presure...and the other 1/2 be so week??...
thanks in advance......
Old Oct 19, 2007 | 07:54 AM
Default RE: 97 s10 blazer
mornin FromTheKing....welcome to the Forum.........great bunch of people to help you....you'l see.......though, it would be a good thing to go to Member Introduction and introduce yourself....check out what need be done, for posting,etc..........have fun here, and good luck with your s-blaz...... again welcome
Old Oct 19, 2007 | 07:48 PM
Rear half of master cylinder applies rear brakes. It may take a while to get strong pressure. If truck has drum brakes it they dont require a large amount of fluid to work. If there a large amount of air in system you will need to go to dealer to get bled. Most shops can't "auto bleed " ABS unit.Hope it helps
Coupe Evil
Apr 6, 2009 11:11 PM
