fuel injection help
Old Sep 3, 2023 | 09:17 AM
johnpaulny's Avatar
Default fuel injection help
Hello - new to the forum. I Have a 1976 Eldorado EFI that was running perfectly until a couple of weeks ago. When warmed up, it would miss, hesitate, actually shook the car because of running so badly. Now it is doing all of that from a cold start as well (seems to have "evolved"). I changed the plugs. The wires are fairly new (when I bought the car). Once the part is delivered, I will change the fuel filter, but I do not believe that is the issue. Any recommendations?
Old Sep 4, 2023 | 07:03 PM
Schurkey's Avatar
Find a Genuine GM service manual.
The various sensors are critical to the operation of the fuel injection. That car is old enough that almost anything could cause problems--coolant temp sensor, manifold vacuum sensor, throttle position sensor, faulty wiring or corroded connectors, faulty circuitry within the computer.
Or it could be as simple as a failed distributor cap/rotor, faulty ignition coil, burned valve--all sorts of non-computer/non-fuel injection systems.
The usual advice when the vehicles were new was to verify all the non-fuel-injection stuff before diving into the F. I.
cadillac tom
Nov 22, 2009 05:37 PM
jerrymac
Apr 26, 2008 01:38 AM
leathenwood
Jun 14, 2007 04:56 AM
mikey250z
Sep 3, 2006 08:53 PM
kingofthe501
Sep 23, 2004 12:43 PM
