472 Oil Pan Removal
Old Jul 16, 2022 | 07:20 PM
impalaman1's Avatar
Default 472 Oil Pan Removal
Rear main seal job on my 71 Coupe Deville:
I'm following my 71 FSM and after removing the starter, center link and exhaust the oil pan cannot be removed. I also remove the timing cover because
I am replacing the timing set as well. I disconnected the oil pickup tube as well. No change.
Are there any tricks to getting this oil pan down or is it simply a matter of raising the engine slightly? The FSM does not mention this.
Thanks!
Old Jul 19, 2022 | 07:46 PM
impalaman1's Avatar
Well I reckon I'll answer my own post. The solution after a fair amount of head scratching was to unbolt the transmission mount and lift the transmission about a 1/2 inch. The oil pan slipped right out after that.
Old Aug 16, 2022 | 12:50 AM
Schurkey's Avatar
Well done. I'd have expected to have to lift the engine. Nice to know that isn't required.
coupeute
Big Block V8s
Oct 12, 2013 10:29 AM
imageres
Aluminum Block V8s
Jul 18, 2011 12:08 AM
92cadi
Dec 31, 2010 07:53 PM
cadworks
Oct 31, 2007 05:56 PM
ahmincha
Oct 4, 2006 09:08 PM
