Eldo 71 engine knocking noise help please
Old Oct 17, 2022 | 08:23 AM
waghorn's Avatar
Default Eldo 71 engine knocking noise help please
My 1971 Eldorado has developed a knocking noise deep in the back of the engine. Comes on when idling and when backing off the throttle but not on the road while moving. It's intermittent and happens more when the engine's cold. Car drives as well as it ever used to and changes gears fine (automatic). Anyone had this before and know the solution? I'm in the UK so not so many places to turn to than I had in the US of A.
Thanks
Old Oct 18, 2022 | 02:37 PM
Schurkey's Avatar
"Deep in the back"?
First Guess: Cracked flexplate.
Second guess: Rod knock.
Can you make it go away at idle by grounding the spark to a particular cylinder? Don't just pull the plug wire off, use a jumper wire or test light to ground the spark.
penn73
Sep 20, 2014 12:44 AM
Right2Bear
Mar 15, 2009 10:29 PM
Scudd
Oct 16, 2008 11:28 PM
starydr
Apr 11, 2008 03:53 AM
Lumpuck
Aug 12, 2006 12:39 AM
