an I remove the oil pan in Northstar engine???
Old Jul 18, 2011 | 12:08 AM
imageres's Avatar
Question an I remove the oil pan in Northstar engine???
I have removed my northstar from my 1997 STS in order to repair the headbolts. With the engine out I started thinking that I should try to renew the oil pan seal. My question is "can I remove the pan without removing the exhaust cross over pie that runs under the pan near the back of the pan. My thought is that if I lifted the front of the engine away from the frame I may be able to move the pan forward and then drop it down and out. Has anyone had this experiance and can comment on the task??
coupeute
Big Block V8s
Oct 12, 2013 10:29 AM
ExBailbonds
Dec 1, 2007 09:33 PM
cadworks
Oct 31, 2007 05:56 PM
pkared
Oct 1, 2007 02:33 PM
Real Cad
Jun 25, 2005 11:13 PM
