1994 el dorado transmossion problem (Help)
Old Sep 16, 2008 | 04:12 PM
ew1600's Avatar
Default 1994 el dorado transmossion problem (Help)
Hi I have a 1994 Cad, El Dorado, It Was parked For about 5 years, and now The Transmisiion wont Shift for Long. From when I turn it on, it will shift ok on all gears for about the first 5 minutes, then after that, it wont move an inch, I added about 2 more quarts of transmission fluid and a bottle of lucas but did not improve. When I had the car turned on I was going to check the transmission fluid level and it started pouring alot of fluid. Is his Nornal? Any advise will Help Thanks.
Old Sep 16, 2008 | 09:47 PM
Default RE: 1994 el dorado transmossion problem (Help)
ORIGINAL: ew1600
HUHH ? is the engine running? idle? what? is it stuck in neutral?
need details.
also go to the FAQ section and read up on CODES, learn how to get them and post them.
Shawn26h
Apr 13, 2010 09:25 PM
Capriceman76
Nov 30, 2007 10:43 PM
Christopherh123
Aluminum Block V8s
Oct 25, 2007 01:59 PM
datdude
Feb 11, 2007 12:56 PM
nizmosis
Sep 26, 2005 10:26 PM
