cherry red exhaust manifold
Old Nov 7, 2010 | 10:39 PM
tony beasley's Avatar
Angry cherry red exhaust manifold
I have a 1995 Seville STS with the 4.6 Northstar. It was overheating,so I put in a new thermostat, heater core, water pump, and radiator. But that's not my concern anymore. Now when I start it up the exhaust manifold turns cherry red and starts smoking. Can anybody tell why,and what can I do to fix this?
Old Nov 9, 2010 | 12:08 PM
Adams' Apple's Avatar
Sounds like your catalytic converter is stopped up....that would explain the overheating, AND the red manifolds.
How long does it take for the manifolds to turn red? If it's immediately, I'd say it needs a new cat. If it takes a few minutes, then it may be running VERY lean, which would also damage the cat(s).
Old Nov 18, 2010 | 11:07 AM
to complicate matters, if the engine was running rich, raw fuel was being dumped into the cat which would also cause a failure.
check codes, report back ...
Old Feb 27, 2023 | 08:12 PM
juanf574's Avatar
wow. i have the same problem. replaced thermostats, water pump, spark plugs, coils throttle body and it still glows red after about 5 minutes. BTW this is not a cadillac but a nissal altima 2.5s
Old Oct 19, 2024 | 01:17 AM
RicknRedmond's Avatar
Default Not unusual for Nissan
I was a factory service rep for Nissan (Calsonic actually) and I noticed on the company car I drove (Nissan Stanza) it was not unusual for the exhaust manifold under the heat shield to glow red hot after driving normally on the highway.
Blake442
Jan 5, 2010 08:41 PM
Maly1973
Oct 30, 2009 03:04 PM
sharon sambursky
Jul 29, 2009 03:26 AM
ChazMan
Jul 4, 2009 11:34 AM
needhelp
Nov 8, 2005 01:20 PM
